Activity Forums VEGAS Pro creating a special effect
  • creating a special effect
    Posted by Steve Lochner on August 24, 2009 at 5:02 pm
    I am trying to create a special effect in vegas pro 9. I have noticed some wedding video’s where they have used a “misty” hazy effect in conjuction with slow motion. How do I create that hazy or misty effect
    thanks
    Shawn Bossick replied 17 years, 1 month ago 2 Members · 3 Replies
  • Shawn Bossick
    August 24, 2009 at 5:17 pm
    go to view, click media generators, select noise texture, select puffy clouds, you will have to tweak the settings for the disered effect, and use key frames to move the effect the way you want it too
  • Steve Lochner
    August 24, 2009 at 5:31 pm
    Shawn
    Thanks, I tried to use the puffy clouds but all I get is the blue and white screen, no video footage, I have tried to change the properties of the puffy clouds, but it still stays blue and white, what am I doing wrong. I have tried placing the clip on a difrent time line, still the same.
    Steve
  • Shawn Bossick
    August 25, 2009 at 4:58 am
    on the clip itself, to the far right, there are three icons click on the top one,now you are in to the properties of the noise texture, then you will need to pull down the alpha chanel on the blue ,which will be chanel A, you will need to add key frames at the bottom where it sais noise texture, it starts with one diamond key frame, go to the end of the clip and change the progress slider, all the sliders are automatable, if you dont add key frames with different timings at the begining of the clip and at the end, it wont move, you have to automate it
