Activity › Forums › Adobe After Effects › Creating a shape layer
  • Creating a shape layer
    Posted by Ben Goodman on February 27, 2014 at 11:12 am
    when I create a shape layer with the star shape layer tool and change the numbers of points or the roundness with the arrow buttons on the keyboard
    the next time I use the star tool It creates by default the same values I used the previues shape I created.
    Is there a way to set the default of the shape layer tool so that every time it will start from a simple star shape?
    Ben Goodman replied 12 years, 5 months ago 2 Members · 3 Replies
  • John Cuevas
    February 27, 2014 at 1:06 pm
    Think that’s the default for AE. You could make an animation preset for the simple star shape and use that when you need it, but if you use the star shape tool again, it reverts to whatever you created last.
    The other method would be to just twirl open the polystar properties and set the points there, then the star tool will always start with the same amount of points, course that’s a couple of extra clicks opening up the properties.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Ben Goodman
    February 27, 2014 at 2:03 pm
    To make an animation preset is a great idea,
    That’s what I’ll do.
    Thank you very much!
  • Ben Goodman
    April 6, 2014 at 1:23 pm
    Well, I finally found a simple solution,
    Double clicking the shape tool button in the tool bar
    will set to the default settings of the shape.
