Activity Forums Storage & Archiving Creating a SAN for the first time
  • Creating a SAN for the first time
    Posted by Ritesh J g on October 22, 2012 at 10:29 am
    Hi Guys, i am completely new to this, and i need help setting up a SAN.
    I am supposed to be using Raid, question is which RAID?
    Firstly i have a HP storage server which holds 12 drive bays that have each 146GB hard drive each.
    Out of the 12 i would like –
    2 disks – holds operating system (was planning to use openfiler)
    10 disks – holds the storage which is resilient
    the main question is how do i get this setup and how do i know what raid to choose?
    this is all the information i have, thank you in advance.
    RG
    Ritesh J g replied 13 years, 10 months ago 3 Members · 4 Replies
  • Bernard Lamborelle
    October 22, 2012 at 11:38 am
    Hi Ritesh,
    Sounds like what you are setting up is not a SAN, but a NAS. With a NAS you can share the storage via standard network protocols such as SMB/CIFS.
    Using RAID 5 means you can lose one physical drive without losing data.
    Using RAID 6 means you can lose two physical drive without losing data.
    RAID 5 typically offers better performance than RAID 6.
    In the end, it depends on how critical your setup is and if you have a backup procedure in place.
    With regards to operating system, your only option should be RAID 1 for mirror.
    Good luck,
    Bernard
  • Ritesh J g
    October 22, 2012 at 1:16 pm
    Thank you Bernerd for your reply so soon, i will give it a try using Raid 5 and Raid 1 for the operating system.
    If i am stuck anymore than i will mail back, but at the moment i may try spend sometime getting the configuration setup.
  • Bob Zelin
    October 22, 2012 at 7:40 pm
    146 gig drives are tiny for this application. How old is your system ? Are these even SATA drives ?
    Bob Zelin
  • Ritesh J g
    October 25, 2012 at 11:14 am
    Hi Bob i was looking for help not to be critisized for what storage i have. And yes the system is an old one which i had since 2007 but i am trying to make use of it
