Activity Forums Zaxwerks Creating a Ribbon with Invigorator
  • Creating a Ribbon with Invigorator
    Posted by Kelly Eddolls on November 23, 2005 at 10:08 pm
    I have done Serge’s tutorial and it’s working well except for two things:
    1) The transparency layer map doesn’t seem to be working. I have a mask that reveals the white strip behind it, and it doesn’t seem to be reading the hi-con info for transparency. (Even when I used the transparency map layer from his project) Is there something I’m missing?
    and
    2) I can only see the texture mapping when my comp is at half resolution, when I go to full resolution it goes back to a plain gray texture.
    Thanks for the help…
    kelly
    Kelly Eddolls replied 20 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
