Activity Forums VEGAS Pro Creating a proxy file for a stream
  • Creating a proxy file for a stream
    Posted by Shelly Somerset on May 27, 2011 at 7:15 pm
    Please help…Im editing a video in Vegas 9.0 and all of a sudden my audio will show no peaks…an error message keeps popping up the says Creating a proxy file for a stream…what do I do???
    Thomas Richards replied 13 years, 1 month ago 3 Members · 6 Replies
  • John Rofrano
    May 27, 2011 at 8:16 pm
    [Shelly Somerset] “an error message keeps popping up the says Creating a proxy file for a stream”
    Are you editing WMV files?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Shelly Somerset
    May 27, 2011 at 8:21 pm
    Yes and I am aware of how you feel about those files…however the files that are missing their peaks are mp3’s…
  • John Rofrano
    May 27, 2011 at 8:47 pm
    I ask because Vegas doesn’t edit WMV audio natively and needs to build audio proxies so this would be normal. I’m not aware of this happening with MP3 files. Do you know if the MP3 files use CBR or VBR (Constant Bit Rate vs. Variable Bit Rate). I’ve seen some problems with some VBR encoded MP3 files. Vegas does better with CBR.
    If you can get them to work, you could always convert them to WAV files but I haven’t had any problems with CBR encoded MP3’s.
    ~jr
  • Shelly Somerset
    May 27, 2011 at 9:13 pm
    Thank you…your always very helpful…have a great holiday weekend
  • John Rofrano
    May 28, 2011 at 3:15 pm
    You’re welcome, you have a great Memorial Day weekend too.
    ~jr
  • Thomas Richards
    August 18, 2013 at 11:33 pm
    Hi. Sorry to revive an old thread, but just thought I’d post here since I’ve found a fix / solution.
    Just convert the video that’s giving you the error to MP4 or AVI and import it back into your project, as a substite. Then the “Error creating a proxy file for a stream” should go away 🙂
    Hope that helps someone out there!
    -Rich
