Activity Forums Maxon Cinema 4D creating a maypole
  • Adam Trachtenberg
    April 22, 2013 at 5:28 pm
    That’s going to be awfully tough, but I would try something like this: 5881_maypole.c4d.zip
  • Victor Camacho guerrero
    April 23, 2013 at 9:48 am
    Thanks so much Adam, this saved my ass from the deadline! More than i expected.
    I managed to create, using your file, a version where the splines are rotating without falling down ( i want to create a shot from above when we can see all the splines rotating).
    There is something i was wondering if it is possible:
    1 – Using a motor to actually move all the splines , so what is rotating is actually the pole and the splines moving according to the rotation of the pole. ( I attached a file where I used a ball and socket connector, which i thought it could reflect better the real rotation).
    2 – if you have a look in the file i created from your file, sometimes in the rotation, the splines does not really get attached to the spheres. I changed many times the point in the constrain and changing the scale of the spline but no success. Any idea?? Anyway, Thanks so much for this Adam.
    5894_maypole.zip
    April 23, 2013 at 10:12 am
    I am not sure how to attach files, but here is the link:https://f1.creativecow.net/5894/maypole
    Many thanks!
