Forums › Adobe After Effects › Creating a mask path by ilystrator…
Daniel Paulo
April 4, 2005 at 2:53 amHelo, felows.
I just wanna know how could i export a mask, or a path in ilustrator to After EFX?
I
Mike Clasby
April 4, 2005 at 3:41 amIn AI. Creat path/mask, Copy it.
In AE. Creat a new Soild Layer (Ctrl Y). Paste into the solid layer.
You should have a mask in that solid layer the same as it was in AI.If you have a problem, try tis from an earlier reply to a similar question:
If you go to prefereneces==>File Handling and Clipboard then check AICB. This should allow you to copy and paste a path from Illustrator CS into AE 6.5
Viewing 1 - 2 of 2 posts
Log in to reply.
