Activity › Forums › Maxon Cinema 4D › creating a lava lamp animation
  • creating a lava lamp animation
    Posted by Victor Camacho guerrero on January 12, 2016 at 11:19 am
    Hello,
    I hope someone could help me with this.
    I have this references:
    https://www.youtube.com/watch?v=sZo6fAtGOd0
    https://www.youtube.com/watch?v=zuyNgyH66qo
    So I need to create some bubbles that moves around the screen with a blobby effect. I am trying using softbody with some turbulence, but I am far to create some inner pressure inside the bubble and move around. I dont think metaballs would work because I would need in most cases more or less a bubble.
    Many thanks!
    Brian Jones replied 10 years, 8 months ago 2 Members · 3 Replies
  • Brian Jones
    January 12, 2016 at 7:44 pm
    it would help a lot to have x-particles (or another capable of fluid sim) but without those, as you say softbodies with turbulence but use a Wind object with turbulence turned on. Also use Areodnamic forces in the soft body and Aerodynamic wind in the Wind object.
    Here’s a test with two Wind objects one with infinite falloff to generally ‘push upward’ with another wind with a cylindrical falloff to push up in the centre like the hotspot of a real lava lamp. Very crude but with more sizes and some tweaking in the soft body tags… 9652_lavalampblobtrial.c4d.zip
  • Victor Camacho guerrero
    January 12, 2016 at 8:39 pm
    Thanks so much Brian,
    which tweaks would you go with the softbodies? By far the most convincing I have achieved in the end, is actually using metaballs and Wind Deformers. I put the wind deformer inside the balls and then animating the metaballs or/and using softbodies. It is far from perfect to be honest.
    Many thanks!
  • Brian Jones
    January 12, 2016 at 10:00 pm
    Stiffness/Flexion settings and Pressure (I just tried bringing that down to Pressure 2 with Volume Conservation at 20 and that’s more ‘squishy’) settings should be most responsible for how deformable the spheres are. I’d also try tweaking the settings of the winds which is better to have at what speed, tweak the turbulence values as well to see if a *lot* of turbulence is better and in which wind it’s better to have the most turbulence… I don’t know if that way or yours is better or something else maybe particles is the way to go – a lot depends on whether you want the separate blobs of your second reference ( an older lava lamp) or the more joined blob of a new lava lamp.
