Activity Forums Maxon Cinema 4D Creating a helix with a flat gardient (no shadows)
  • Creating a helix with a flat gardient (no shadows)
    Posted by Stuart Samuels on May 19, 2015 at 12:44 pm
    Hi.
    I’m to create a helix that has a gradient (Black>Grey>White) but renders without shadows, effectively making it look 2d. Is this possible?
    I have my helix with a gradient applied (I’ve tried applying the gradient in both the colour and luminance channels) but I can’t figure out how to render without the shadows etc that give it the 3d look. I’ve tried playing with multipass settings but with no luck.
    Below is where I am currently up to.
    For bonus points, I’d like to know how to taper both ends. The Sweep Nurb only lets me taper the end.
    Thank you in advance.
    Stuart Samuels replied 11 years, 4 months ago 2 Members · 5 Replies
  • Adam Trachtenberg
    May 19, 2015 at 8:31 pm
    You had the right idea using the luminance channel. Put the gradient in luminance and disable all the other channels and you should get what you’re after.
  • Stuart Samuels
    May 20, 2015 at 8:45 am
    Thanks Adam.
    I’ve done that but it’s still not looking quite right….
    As you can see, there are still shadows etc. Am I missing something?
    Thanks again.
  • Stuart Samuels
    May 20, 2015 at 8:51 am
    Ah, I see my problem. I just needed to change the gradient type from 2d-Star to 2D-V.
    Thank you!
    Any suggestions on making it taper at both ends?
  • Adam Trachtenberg
    May 20, 2015 at 4:34 pm
    Cool.
    You can make the helix taper but twirling down the sweep object’s “Details” menu and adjusting the scale graph. Ctrl + Click the line to add points.
  • Stuart Samuels
    May 21, 2015 at 1:41 pm
    That worked perfectly. Thank you once again.
