Activity Forums Apple Final Cut Pro Legacy Creating a HD DVD using type 5 DVD.
  • Shane Ross
    April 24, 2013 at 8:36 pm
    There are HD DVD presets in Compressor…use those.
    And you know that ONLY Macs and Toshiba HD DVD players will play these back, right? HD DVD is a dead format…lost to BluRay.
    Shane
    Little Frog Post
  • Shane Ross
    April 24, 2013 at 8:37 pm
    You can make BluRay disks with regular DVDs and the DVD burner. You just need to use the SHARE option to do that. And I think you are limited to a running time of 10-15 min.
    Shane
    Little Frog Post
  • Kevin Blum
    April 24, 2013 at 10:15 pm
    How do I do this? Using DVD SP?
  • Shane Ross
    April 24, 2013 at 10:16 pm
    Make BluRay? You use the SHARE option directly from FCP. BluRay is an option.
    Shane
    Little Frog Post
  • Kevin Blum
    April 25, 2013 at 6:28 pm
    Thanks Shane. Never knew you could do this.
  • Mark Suszko
    April 25, 2013 at 7:52 pm
    It’s not ideal, (share function off the timeline) but I’m grateful for it all the same: if you make PSA’s and commercials or news clip VNR packages, that’s a long enough duration to distribute a high def product via the BluRay instead of an FTP or more expensive tape process. And the BD makes a great shelf archive.
  • Bret Williams
    April 27, 2013 at 1:52 am
    It’s not really a bluray. It’s an AVCHD at about 1/3rd the bit rate of regular bluray. But they look great. If you just make a file you can take it over to toast and make basic menus.
