Activity Forums Apple Final Cut Pro Legacy Creating a FCP Online System
  • Creating a FCP Online System
    Posted by Don Unverrich on May 14, 2006 at 9:04 pm
    This is my first post so here goes.
    I need some advice on putting together an FCP HD Online system. I am working on a lower budget film that was shot with the CineAlta (about 30hrs worth). We had the tapes down converted to DVCam and we edited the film. I was now approached to do the online. I have checked out Ken Stone
    Shane Ross replied 20 years, 3 months ago 2 Members · 3 Replies
  • Shane Ross
    May 15, 2006 at 12:31 am
    I think 6GB of RAM is overkill. 4GB should do you nicely. More if you plan on having more than one application open.
    SATA Raid like the Silver SATA V by Weibetech, or the Sonnet Fusion 500P that gets you about 2TB @ 200MB/s for about $3000. Or an XServe Raid, Ciprico (formerly Huge Systems) MediaVault 4210 which are both Fibrechannel. But they pretty much start at $6000 for about 1.25TB – 2TB and get you about 350MB/s…depending on how many drives you have.
    Then you need the Capture Card. Good ones by Decklink and AJA run about $2000. Both are good performers and will do you well.
    HD Monitor. YOu can cheat a little and get the Sony PVM-14L5 for $1500, and then the $1400 HD SDI card for it for $2900 total. It has 800 scan lies of resolution, and I’m telling you, I saw one next to the Sony 34″ HD CRT and the image looked exacty the same to me.
    Then you can either color correct with the FCP tools, which are good, or get Final Touch for $4000 or Color Finesse for about $500 (FCP Plugin) – $2000 (HD Standalone application).
    Then you need to rent whatever deck you will be outputting to…so your $10k gets eaten up fast, and ONLY for the equipment. That doesn’t even cover the talented operator who you need to pay.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Don Unverrich
    May 15, 2006 at 1:48 am
    Thanks for the info Shane. About the SATA, I have thought about those but have heard that when they get more than half full, they start loosing their transfer speed causing dropped frames. I guess you can get a large enough array so you don’t fill it half full, but have you come across this? Thanks again.
    Don
  • Shane Ross
    May 15, 2006 at 5:58 pm
    Half full…no. But approaching 80-90%, yes.
    But this is true of ANY drive. Even the huge fibrechannel Raid arrays
    Shane
    Alokut Productions
    http://www.lfhd.net
