Activity Forums Adobe After Effects Expressions Creating a Customer Transition
  • Creating a Customer Transition
    Posted by Adam Nelson on November 13, 2014 at 10:45 pm
    I’m attempting to make a custom transition that is driven by a null object that moves from the top-right of the comp to the bottom left of the comp. In order to make the transition as user-friendly as possible for my client, I’ve been trying to come up with an expression that links the diagonal movement of the null object to a slider control so my client can simply slide the value of the control from 0 to 100 to animate the effect. I’d also like to make the expression versatile enough that I can re-purpose it onto a comp of any size, which I believe means using a thisComp.height and thisComp.width to extract the starting/ending values of the null.
    Any help would be greatly appreciated!
    Adam Nelson replied 11 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 13, 2014 at 11:26 pm
    Try this:
    s = effect(“Slider Control”)(“Slider”);
    linear(s,0,100,[thisComp.width,0],[0,thisComp.height])
    Dan
  • Adam Nelson
    November 13, 2014 at 11:31 pm
    Fantastic! It works like a charm!
    And, I believe I see what I was doing wrong this whole time.
    Many thanks,
    Adam
