Activity Forums Adobe Illustrator Creating a Continuous Gradient of a Group of Outlined Text
  • Creating a Continuous Gradient of a Group of Outlined Text
    Posted by Kyrsten Sanderson on April 15, 2009 at 9:50 pm
    Maybe someone can help me with this one…
    I have a group of outlined objects that I want to apply a continuous gradient to. When I select all the objects and apply the gradient it applies the gradient to every object instead of treating the object as a group.
    How do I apply a continuous gradient to a set of separate objects?
    I would appreciate any advice.
    Thank you!
    Thie Thomsen replied 17 years, 4 months ago 3 Members · 2 Replies
  • Adolf Witzeling
    April 16, 2009 at 12:23 pm
    select all the outlined objects, then go to OBJECT…COMPOUND PATH…MAKE. Then apply your gradient.
    Hope that helps,
    cheers,
    Adi
  • Thie Thomsen
    April 16, 2009 at 2:30 pm
    Select the objects you would like to apply the gradient to, select the gradient in your swatches and use the Gradient tool (hotkey : g) to draw the gradient over all on the selected objects.
    The compound path way (as offered by Adolf) also works, but this method is a bit less destructive.
    I can see your spot colours…
