Activity › Forums › Adobe After Effects › Creating a character out of paper pieces
  • Creating a character out of paper pieces
    Posted by Bruce Benamran on February 4, 2009 at 2:10 pm
    i’d like to have a character made of paper pieces (with an id photo for the head); it’s for a deam sequence.
    my idea is having pieces of paper for :
    – one for the torso
    – two for the arms and hands
    – two for the legs and feet
    – a photo for the head
    i’d like to animate it then.
    i thought of the puppet tool to do that, but each time i try to use the puppet tool, it distorts the pieces of paper instead of simply moving them.
    So here’s my question :
    should i be using the puppet tool to do that, of should i animate the layers separately, having cleverly set the anchor points (at shoulders and hips) and having parented everything to the torso ?
    Bruce Benamran replied 17 years, 8 months ago 3 Members · 3 Replies
  • Jon Etheridge
    February 4, 2009 at 2:56 pm
    Hey man.
    I would go your second rout by setting the anchor points and parenting everything to the torso and animating each part individually.
    I use that style a lot for my cartoons. See some examples here. https://vimeo.com/1988217
    and if you have any questions feel free to ask.
    Jon Etheridge
    Appsro inc
    jon@appsro.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Jeremy Richardson
    February 4, 2009 at 3:46 pm
    Alternatively you can modify that workflow slightly and implement inverse kinematics. This will allow you to animate one layer and the others will follow along.
    https://www.motionscript.com/design-guide/ik.html
    Jeremy Richardson
    http://www.justjerm.com
  • Bruce Benamran
    February 4, 2009 at 4:04 pm
    Thanks, i saw your demo and that’s really the kind of effect i’m looking for…
    i guess, then, that i’ll go with anchors and parenting, and then precomp the animation in a layer…
