Activity Forums Adobe After Effects creating a burned effect as a transition
  • creating a burned effect as a transition
    Posted by Tielman Dewaele on March 9, 2007 at 12:52 pm
    Jip,
    I liked to create in FCP or AE, a sort of burned effect(like on pelliculle) between two clips.
    Its been done very offen in surffilms, but the client wants it that way…
    I want it as a transition, so i can you use it in my edit in FCP. It has to be realistic. Not toon-like.
    Any suggestions?
    T.
    Peace
    Steve Morris replied 19 years, 6 months ago 2 Members · 1 Reply
  • Steve Morris
    March 9, 2007 at 2:11 pm
    I created something last week that looked very good. I did not use it as a transition, but it could easily be a transition. I wanted to burn a hole in a book page. I just laid a large piece of white poster board (I did not have black paper around) on the snow, poured a little circle ( I needed a ring of fire)of gasoline on it, turned the camera on & lite the fire. I videoed the fire from the same perspective that my 3D comp camera was in. I masked out and feathered the areas on the fire video that I did not need. The white paper matched my book pages perfectly. I also used CC Page Burn to reveal the page underneath. For a transition, you could use CC Page Burn to burn off the entire page.
    The entire process took 15 min. I spent more than that much time searching the net on making fire in AE.
    I am still looking for a good fire tutorial.
