Activity Forums Apple Final Cut Pro Legacy Creating a 16X9 DVD from 4X3 footage in Final Cut
  • Creating a 16X9 DVD from 4X3 footage in Final Cut
    Posted by Jpfilms on September 3, 2006 at 2:32 pm
    Hi All,
    I’m would like to take my 4X3 footage and create a widescreen dvd. I’ve nested my sequence and used the widescreen filter. Is this possible without creating a distortion to the footage? Any advice is greatly apreciated.
    Neil Ryan replied 20 years ago 2 Members · 1 Reply
  • Neil Ryan
    September 3, 2006 at 10:46 pm
    If, as you say, you don’t want to create any “distortion to the footage” then you must blow up the footage from 4×3 (16×12) to 16×9 and mask off the top&bottom of the footage.
    You’re not ‘distorting’ the footage, as in changing the original aspect of the image, but you will lose quality in the blow up process.
    Pillarboxing is an option.
