Activity › Forums › Adobe After Effects › Creating 3d tunnel for an absolute beginner
  • John Williams
    February 10, 2020 at 10:13 am
    Hi there, this is possible in After Effects without any plug-ins needed.
    I can either give you a step by step guide how to do it or send you a project file with the tunnel effect created that you can deconstruct and reuse as you wish.
    Please just let me know;)
    John Williams
    Soho Editors
  • Tyler Maag
    February 10, 2020 at 1:36 pm
    Thanks for your reply John! If you would be willing to share a project file I would greatly appreciate it! could you send to maagbtyler@gmail.com? Thank you for your timely response!
  • John Williams
    February 11, 2020 at 10:15 am
    Hi there, here’s a link to the project file.
    As it’s built in the Cinema 4D renderer in After Effects i’d recommend working in the ‘Fast Draft’ mode when animating as it is much faster.
    You will see 5 comps just to show the different stages. Stages 4 & 5 are the more finished ones. Please not it’s been created in CC2020 so won’t open in earlier versions.
    https://sohoeditors.com/download/Forum%20Questions.aep.zip
    Hope that helps;)
    John Williams
    Soho Editors
  • Tyler Maag
    February 11, 2020 at 2:04 pm
    Thanks John it is definitely the look im going for! Pardon the perhaps dumb question but as far as animating it would I trace the 5 bar comps, add a solid above the comps then apply e3d and assign the custom masks and extrude? Thanks again for your help!
  • John Williams
    February 11, 2020 at 2:23 pm
    Hi there, not totally clear on what you are saying when you say ‘trace’ and ‘e3d’ and assign the custom masks and extrude.
    3D comps like this are unfortunately not that simple so I created this one as simple as possible. It depends what you want to animate but if you move the Camera layer through the tunnel all the 3D layers will respond to the movement.
    John Williams
    Soho Editors
  • Tyler Maag
    February 11, 2020 at 3:24 pm
    Sorry for confusion, sounds good I will use the camera layer and mess around with it, I appreciate it!
