Activity › Forums › Adobe After Effects Expressions › createPaths() to draw a line between two nulls has a periodic random glitch
  • createPaths() to draw a line between two nulls has a periodic random glitch
    Posted by Kyle Venberg on November 29, 2021 at 11:49 pm
    Hello,
    I’m using After Effects 22.0.1 (Build 2) and experiencing a very strange render glitch. I built a heavy expressions title template and have two nulls where their location is changed based on a number of controls. A line is drawn using createPaths() and the locations of the two line points are determined by the null points. As seen in the screengrabs attached, you will see a blue line (representing the createPaths() line) but for some reason, the line draws to a different location on random singular frames. If I zoom in, zoom out, change an unrelated property in my project, the animation periodically plays correctly but then randomly has the createPaths() render glitch again. Any suggestions or need any additional information to help debug, let me know!
    Kyle
    Kyle Venberg replied 4 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
