Create sort of Metadata in AE project (AE Script)
I am woking on a script that creates different types of comps. And I am searching for a way to store some data for each comp somewhere in the project or in the comp itself. this data act sort of Metadata, So I can use it to recall the comps and read some comp’s properties like color, size, number of layers…etc. and update them if I need to.
I was thinking of using a hidden null layer with keyframes in each comp and store these info/Metadata as keyframes by reading its values and convert it to data or maybe adding markers. But since I am fairly new in AE Scripting I would like to ask for any advice or suggestion of what the most efficient solution to store this kind of metadata.Thanks in advance
Haider Najeeb
Art Director and Motion Designer
http://www.htn3d.com
