Create ripples through particles
I need to be able to cause ripples in an existing particle field as someone walks through them. I am working on a play where a character walks through stars projected onto the set, and the stars need to react as she walks, then eventually come to a standstill. I own After Effects CS6 and Trapcode Particular, and I’d be willing to buy trapcode form if I knew that it would work.Thanks!
