Activity Forums Adobe After Effects Create replicable comp
  • Create replicable comp
    Posted by Francesco Benciolini on June 17, 2019 at 11:02 am
    Hi, i’m having a problem and i struggle even to come up with keywords to search for it:
    I’m making a series similar to this one:
    https://www.youtube.com/watch?v=jWG9CD3nkGA
    I made a little animated face with controllers from joysticks ‘n sliders and with arms made in rubber hose, and it works pretty well, now i need to make it as an effect so that when i copy it in a new comp a and animate it without messing the animation in other comps, is it possible? i tried to create a project in after effects and than import that project inthe main one every time i need a new copy, but it messes up the expressions.
    as an other way to put it: if i create a motion template file for premiere then if i put multiple copies of it in a timeline every copy has his own parameters, changing them in a new copy will not reflect in already present ones.
    i need to do the same with a comp in aftter effects.
    To duplicate the comp would be very difficult because it has nested comps and changing the name would break some expressions
    Is there a solution i am missing?
    Thank you in advance 🙂
    Post Production Supervisor
    Kondoo Video
    Milan, Italy
    Michael Szalapski replied 7 years, 3 months ago 3 Members · 2 Replies
  • Eric Santiago
    June 17, 2019 at 1:11 pm
    It’s early in the morning but I’ll take a stab at this.
    Can you save the file and just re-import each file as a different project?
    I do this all the time and this way the nested pre-comps don’t get lost.
  • Michael Szalapski
    June 20, 2019 at 9:12 pm
    It sounds like you need to look into Master Properties. You can have as many instances as you want of your character comp – all with different values for each one!
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
