Activity › Forums › Square Box CatDV › Create PDF from catalog?
  • Create PDF from catalog?
    Posted by Jason Brown on July 21, 2011 at 2:58 pm
    I need to create an electronic version of some media to a group that needs to look through about 700 clips…with searchable metadata and proxies (I’ve already created).
    Is there a function to send a catalog to a viewable file format like a PDF?
    -Jason
    Rolf Howarth replied 15 years, 2 months ago 3 Members · 5 Replies
  • Matthew Stamos
    July 21, 2011 at 5:17 pm
    Yes load the view you want to export list grid or thumbnail and select under the edit menu print current view.
  • Jason Brown
    July 25, 2011 at 11:04 am
    I’m about 80% of the way there…thanks for this post! 🙂
    One more question, how can I make text larger? I’m using a modified view using poster frame and thumbnail sequence view, but notes in my text field are very small. Also, if they go too long, they get cropped. Even with a hard return in the field.
  • Rolf Howarth
    July 27, 2011 at 8:59 pm
    Print as an HTML Formatted view, that will wrap a long Notes field onto as many lines as it takes.
  • Jason Brown
    July 28, 2011 at 2:30 am
    Thanks Rolf…that worked perfectly.
    I’m printing to PDF after outputting via HTM and the page breaks are breaking the fields into pieces.
    I have 3 text fields below a filmstrip thumbnail…is there anyway to force the name-thumbnail-and 3 text fields all together and break to new page instead of breaking them apart?
    -Jason
  • Rolf Howarth
    July 28, 2011 at 9:24 pm
    There isn’t I’m afraid, other than printing them out one by one. We’ll make a note to look into adding an option for that however.
