Activity Forums Maxon Cinema 4D Create object without Caps ?
  • Create object without Caps ?
    Posted by Chris Holland on August 29, 2008 at 1:13 am
    Is there a way to not create caps when you turn something into an object. For example:
    I import and .ai spline. I use extrude nurbs to give it depth. I make it an object. When I do this it gives me caps on both sides. I can delete the caps and use close Polygon hole to make it a polygon.
    My question is is there a way to skip this step and have those caps be polygons right away ?
    I hope this question makes sense. Thanks.
    Chris Holland
    Editor/Animation/Design
    hollandedit.com
    Chris Holland replied 18 years ago 2 Members · 2 Replies
  • Brian Jones
    August 29, 2008 at 2:05 am
    the caps are polygons when you make the Extrude editable (or do a Current State to Object). Just select the caps and the main body and Functions/Connect, this makes a new object with all the bits you connected (you can keep the old one or toss it) then do a Functions/Optimize.
  • Chris Holland
    August 29, 2008 at 3:57 am
    Great. Thank you.
    Chris Holland
    hollandedit.com
