Activity Forums Adobe After Effects Create Null from Paths – only working with closed Paths?
  • Create Null from Paths – only working with closed Paths?
    Posted by Isa Dimpfl on January 14, 2019 at 2:01 pm
    hi all,
    i want to parent a hand to an “arm” which is just a shape path in AE. the path has 3 points: shoulder, elbow and wrist. i want to parent an illustrator layer (hand) to the last point of the path (wrist).
    when i select the path and click the “create nulls from paths” script i get an alert “error: no paths selected”.
    does this script only work with joined paths eg. a rectangle?
    is there an other solution for my problem?
    thank you!
    isa
    Chris Green replied 7 years, 4 months ago 3 Members · 2 Replies
  • Ahmed Emad
    January 19, 2019 at 11:50 am
    hi
    Be sure that u selected (PATH) under (Path1) under (shape1)
    but in your case i see that better to use duik bassel plugin or rubber hose plugin, its better for rigging characters
    duik for cut out illustrations characters
    rubber hose for strokes characters
  • Chris Green
    April 15, 2019 at 12:41 am
    Hey Isa, I’ve had similar troubles with elipses and rectangles. Try right click>Convert to Bezier Path. Should be recognised as a path then.
    Duik Bassel and RubberHose2 are good go-to’s for light-medium duty rigs, so unless you’re creating a really robust rig I’d do as above poster mentioned and look at those as options.
