Activity Forums Adobe After Effects Create human shapes with particular, and then animate them.
  • Create human shapes with particular, and then animate them.
    Posted by Chris Wood on April 17, 2012 at 4:39 pm
    Ok so I have a fun little project as part of my VFX scenes for my Skyrim short film.
    I need to re-create a particular dragon-shout from the game, Aura Whisper.
    This is a kind of magic that enables you to see living beings through walls etc.
    And it’s represented by a shimmering, red cloud-like particle glow around the characters basic skeleton.
    If you look here:
    https://www.youtube.com/watch?v=2jCb9oIKkgw
    You can see what I mean.
    Now, this is what I want to do.
    Film some footage of some densely-packed trees.
    Make it appear darker in AE
    When the Aura Whisper is performed by my actor, the scene lights up a bit, and you can see the red mist moving across the trees, sneaking around.
    I’m wondering how I can get particular to form a human shape, and then animate it so that it looks like a human form, obscured by normal view, is then sneaking through the trees.
    Any help on this would be great.
    Thank you!
    Chris Wood replied 14 years, 5 months ago 4 Members · 8 Replies
  • 8 Replies
  • Roland R. kahlenberg
    April 17, 2012 at 5:03 pm
    Trapcode Form will provide a better solution. Checkout this relevant COW Tutorial from Eran Stern.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Chris Wood
    April 17, 2012 at 6:19 pm
    Do you think the best option would be to get greenscreen footage of a person sneaking around, then use the trapcode form effect, then move that into the comp of the trees, aye?
    Seems good to me!
    April 17, 2012 at 8:16 pm
    It all depends on how tight a matte you require to be around the talent and this depends on the effect you have in mind. If you need a very accurate matte of the actor and don’t want to roto then a chroma backdrop will have to do but things brings in complications related to the distance your actor has to move during each shot.
    If a loose matte is fine then shoot on the actual set/scene/backdrop and use mochaAE/Pro to track, to help you get a quick matte from which to feed into Trapcode Form.
    Cheers
    RoRK
  • Chris Wood
    April 17, 2012 at 9:16 pm
    Na it’s fine, we have a video studio at Uni with a large green screen. Should be alright!
    What I’m worried about now is the cloud density. I suppose I could just duplicate it and mask out the arms, except when they cross over the body (to give the impression of 3D depth)
    April 18, 2012 at 12:09 pm
    Start messing about with Trapcode Form to get a feel for what you need to feed into it and how you can control the properties that are integral to making the shot work for you.
    Good Luck!
    RoRK
  • Katherine Taylor
    April 19, 2012 at 12:01 am
    Simulating a “z-depth” pass , with gradients and masks, could also help create some depth for Form to use.
  • Siddharth Gautam singh
    April 21, 2012 at 12:13 pm
    You can do this in Particular as well, using your matted footage as a layer emitter. You can emit particles from this layer and add wind and turbulence effects. Could get close to the kind of effect you are looking at.
  • Chris Wood
    April 25, 2012 at 5:14 pm
    Could you give some hints on how to make the particles form the human shape I have masked out? Not having much luck myself.
    Thanks.
