Activity › Forums › Adobe After Effects › Create Edge to Edge Loop
  • Create Edge to Edge Loop
    Posted by Mkleo Hafele on August 9, 2019 at 9:23 am
    Hi all,
    i´m looking for a way to achieve the following, if an element moves outside the edge of the composition, (so half of the element gets invisible) it should enter again on the other side of the composition (so one half of the element is shown on the right edge, the other hald is shown on the left edge). Like on PacMan, when the PacMan leaves on the right, it automatically enters from the left again.
    I have a screen wrapped arround a column, for creating the animation i “unwrapped” it, so left and right end of the screen need to be the same so you won´t see a cut when its shouwn arround the column.
    Mkleo Hafele replied 7 years, 1 month ago 2 Members · 2 Replies
  • Roei Tzoref
    August 9, 2019 at 8:40 pm
    instead of actually moving it, place the whole shape next to the corner of the composition, then use the offset effect on the layer and use the shift center to parameter to movie it.
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
  • Mkleo Hafele
    August 12, 2019 at 7:11 am
    thanks, thats exacly what i was looking for 🙂
