Activity › Forums › Adobe Illustrator › Create custom batch action on Adobe Illustrator
  • Create custom batch action on Adobe Illustrator
    Posted by Antonio Rossi on December 14, 2016 at 11:58 am
    i need to create an action for processing in batch a big number of images and files
    (find attached a picture that completes the explanation).
    This is the steps:
    1- Open the file “BASE.AI” (a file which contains a big quantity of vector groups “A”, “B”, “C”… (etc.)).
    2- Select and copy the group “A”.
    3- Open another file named “GENERIC TEMPLATE.AI” (a standard model).
    4- Paste and edit (rotate, resize, move..) the copy of the group “A” into the “GENERIC TEMPLATE.AI” .
    5- Save the “GENERIC TEMPLATE.AI” as a new file EPS (version 8) named progressively (NEW 1.EPS, NEW 2.EPS, NEW 3.EPS…).
    6- Close all.
    Repeat all the same steps for the other vector groups:
    – From the group “B” create the file “NEW 2.EPS”,
    – From the group “C” create the file “NEW 3.EPS”,
    etc..
    I do not understand:
    – How i can to create a batch action process that, every time, start from the selection and copy of a new object (groups “A”, groups “B”… etc.) that is placed in a different position of the file “BASE.AI”?
    – How i can record the action of copy the vector groups “A” (contained in the file “BASE.AI) and paste into another file (the file “TEMPLATE.AI)?
    – How i can record the action of save always in EPS format Version 8 (without manually select this option in each saving)?
    I will be very grateful for any suggestions or help received also for some single steps.
    Thank you very much.
    Antonio Rossi replied 9 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
