Activity Forums Maxon Cinema 4D Create Clean Spline Wrap
  • Create Clean Spline Wrap
    Posted by Pete Tong on February 23, 2016 at 3:19 pm
    I am trying to create the lips like this reference. I am not able to create a clean spline. I used the spline wrap using a capsule to wrap around a spline. However, you can still see the seamlines even though I used a connect array object. Could someone please help me with this?
    This is my settings!
    Thank you!
    Andy Sills replied 10 years, 7 months ago 3 Members · 2 Replies
  • Brian Jones
    February 23, 2016 at 4:45 pm
    probably better to use a circle spline in a Sweep with your lip spline rather than a capsule spline wrapped. That will give you the same shape but will give a closed shape (if your lip spline is closed).
  • Andy Sills
    February 25, 2016 at 5:00 pm
    ^^ Definitely the way to do it here, your object is “ending” so your tube ends as well.
