Activity Forums Adobe After Effects Expressions Create Audio Amplitude with ExtendScript – no mouse clicks
  • Create Audio Amplitude with ExtendScript – no mouse clicks
    Posted by Martin Bollerup on February 14, 2013 at 10:24 am
    Hey guys
    Is there any way of creating the Audio Amplitude layer with ExtendScript only? This should be done with no mouse clicks as it is a 100% automated process.
    If you’ve got any alternative ideas – such as using the Audio Waveform Effect to manipulate a Solids color from white to black and then get the amout of black as a value from 0-255 or 0-100 or 17-17.3. Or extracting the waveform to a vector path and then measuring the height of the element?
    thanks
    Martin
    Mitch Mann replied 13 years, 7 months ago 3 Members · 3 Replies
  • Dan Ebberts
    February 14, 2013 at 2:20 pm
    You can execute this command:
    app.executeCommand(app.findMenuCommandId(“Convert Audio to Keyframes”));
    If you have CS6, you can make sure your comp has focus and the layer is selected first, otherwise you have to do that by hand.
    myComp.openInViewer();
    myComp.layer(1).selected = true;
    Dan
  • Martin Bollerup
    February 14, 2013 at 2:34 pm
    Whoooha!!!
    martinComp.openInViewer();
    martinComp.emotions(“HAPPY”).value = true;
    Thank you Dan – once again you save the day (and I learned something new) 🙂
    Martin
  • Mitch Mann
    February 15, 2013 at 3:11 pm
    A related curiosity: if activeItem is null (because timeline or viewer don’t have focus). Is there a way to use openInViewer to give focus to the comp that’s already open?
