Activity › Forums › Adobe After Effects › create a stream of arrows
Posted by Linda Vieira on October 15, 2011 at 12:18 pmUrgent need to create a path with arrows (like a stream of arrows), where particles are tracing the same path.
How can I do this?
Tks
Andrea Szabó replied 14 years, 11 months ago 4 Members · 3 Replies -
Roland R. kahlenberg
October 15, 2011 at 7:46 pmIt all depends on the shape of the path and how accurately the arrows traverse along this path. Perhaps you can provide a scanned sketch?
Cheers
RoRKIntensive AE & Mocha Training in Singapore and Malaysia.
Tudor “ted” jelescu
October 17, 2011 at 10:11 amThe last post in this thread may help you:
https://forums.creativecow.net/thread/227/1065#1067Also, if you have Particular you can use it to do this kind of animation. If I remember well, this tutorial may have some pointers on how to do that:
https://maltaannon.com/articles/after-effects/particular-2-overview/Tudor “Ted” Jelescu
Senior VFX Artist -
Andrea Szabó
October 21, 2011 at 2:54 pmHi Linda,
There is an effect which helps you create a stream, It’s called Echo. If you have the arrow, draw the motion path it follows. After that, you should make a new adjustment layer and place it above the arrow. Then pre-compose them. Now you can use the Echo effect as you wish on the compsition.
Andi
Easy Explain Video
Creator of great explainer videos
https://www.easyexplainvideo.com
