Activity Forums Adobe After Effects Create a slideshow template to use in Premiere Pro
  • Create a slideshow template to use in Premiere Pro
    Posted by Lisa Newton on July 10, 2018 at 9:04 am
    Hello ????
    I need to create about 70 slideshows all based on the same template…same number of images, same simple animations, same duration. I’m just not sure about the most efficient way to produce the master template. Basically, I want to create a slideshow in After Effects and drop the new images onto the template multiple times in Premiere Pro. Can I create a mogrt with placeholders for the images? Could I use dynamic links?
    I’m using mogrts for the text animations but can’t work out how to simply swap the images in a drag & drop manner.
    Lisa
    Lisa Newton replied 8 years, 1 month ago 1 Member · 1 Reply
  • Lisa Newton
    July 11, 2018 at 3:47 am
    Thanks Dave. Is it possible to save it as a template so I can drag and drop the new images for each version?
    I feel like there must be a faster way than copy and pasting the attributes for each image…just can’t think how ????
