Activity › Forums › Adobe After Effects › Create a silhouette in a door opening
Tim Fast replied 16 years, 2 months ago 3 Members · 13 Replies
Kevin Camp
July 1, 2010 at 6:42 pmi have a feeling that there is something fairly simple that we are overlooking that is preventing yours from working correctly.
i hope you don’t mind, but, i put this together so you might be able to compare it to what you have. it’s a bit simpler than yours, but it works as described…
here’s screen shot…
and here’s the project (cs4)…
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Tim Fast
July 1, 2010 at 6:49 pmYes, full size. No, no masks.
Kevin is it asking too much if you could build a simple composition as described above and post the result here? It would take like 10 minutes and we would get the answer what the problem is.
Tim Fast
July 1, 2010 at 7:17 pmHaha, while I were typing you did exactly what I asked for. 🙂 Thank you!
Anyhow, after I looked at your project, I realizes that I didn’t succeed to find the right combination between Threshold and Radius. I had higher values for both. I tried the same settings as you have and it worked better.
However, I still get some artifacts at the shadow and discoloration of the floor around it. So you do in your example. Besides, the lower Threshold I set, the more impact it has on the lightened parts of the walls which decreases the texture detail. In my final composition I will have the foreground lit well but the glow effect might interfere with it.
Anyhow, I guess I will have to play a little more with the settings and figure out how it works.
Thanks a lot for all your help! It feels really nice to know that there are people that spend there free time to help others to get better in something. 🙂
