Activity Forums Adobe After Effects Expressions Create a Shape Ellipse from Nulls
  • Create a Shape Ellipse from Nulls
    Posted by Rubens Angelo on August 30, 2019 at 3:37 pm
    Hi all,
    I wanted to create a Shape Ellipse from some Nulls(I have 300) in same position from every Null and parent it.
    I’m not that great on expressions, I even managed to create a single solid but I can’t even color or resize it even using rd_GimmePropPath to get these properties
    I am running a script file… any tips?
    Thanks for your attention,
    Rubens
    app.beginUndoGroup("Add new shape layer");
    var myEllipseSize = [500,500];
    var myFillColor = [230, 130, 30];
    var firstNull = 30;
    var lastNull = 330;
    var curComp = app.project.activeItem;
    if(curComp){
    for(firstNull; n < lastNull;n++){
    var shapeLayer = curComp.layers.addShape();
    var shapeGroup = shapeLayer.property("Contents").addProperty("ADBE Vector Group");
    shapeGroup.property("Contents").addProperty("ADBE Vector Shape - Ellipse");
    shapeGroup.property("Contents").addProperty("ADBE Vector Graphic - Stroke");
    shapeGroup.property("Contents").addProperty("ADBE Vector Graphic - Fill");
    shapeGroup.content("Fill 1").color = myFillColor;
    shapeGroup.content("Ellipse Path 1").size = myEllipseSize;
    shapeGroup.content("Ellipse 1").content("Ellipse Path 1").size; // Just try
    app.endUndoGroup();
    Rubens Angelo
    http://www.movee.tv
    Rubens Angelo replied 7 years ago 1 Member · 1 Reply
  • Rubens Angelo
    August 30, 2019 at 8:55 pm
    I got what I wanted! hahahaha
    It was very rough but it worked,
    best
    var myEllipseSize = [90,90];
    var myFillColor = [230, 130, 30]/255;
    var firstNull = 29;
    var lastNull = 333;
    if(curComp){
    for (var i = firstNull; i <= lastNull; i++){
    shapeLayer.parent = curComp.layer(i+1);
    shapeLayer.moveAfter(curComp.layer(lastNull+1));
    shapeGroup.content("Fill 1").color.setValue(myFillColor);
    shapeGroup.content("Ellipse Path 1").size.setValue(myEllipseSize);
    shapeLayer.transform.position.setValue(curComp.layer(i+1).transform.position.value);
    shapeLayer.transform.position.setValue([0,0]);
    app.endUndoGroup();
    Rubens Angelo
    http://www.movee.tv
