Activity Forums Adobe After Effects Create a path over an aerial video of mountains?
  • Create a path over an aerial video of mountains?
    Posted by Susan Dempster on November 11, 2009 at 6:08 pm
    I’m new to After Effects – I’m not sure if this is even possible…
    I have an aerial video of a mountainous region that I want to draw a winding pathway over. I have GPS coordinates for this pathway, and can reference this in google earth software. Is there a relatively straightforward way to create this pathway over all the hills and mountains, without having to draw frame by frame (Which is just about the only way I can think to do this in Final Cut)
    Any suggestions or ideas would be greatly helpful!!!
    Jim Dodson replied 16 years ago 3 Members · 6 Replies
  • Jim Dodson
    November 11, 2009 at 6:41 pm
    Drawing a path over some video is as simple as crating a Mask using bezier points to make the shape and curves you desire then adding the “Generate–>stroke” effect to that mask.
    It only gets complicated if there is motion in your video — if that is the case you would need to motion track your footage to keep your stroked mask locked to your footage…
    So question 1:
    Is there motion in your video?
    Question #2:
    Am I understanding your needs correctly?
    Jim Dodson
    8 Core Intel — Mac – OSX
  • Susan Dempster
    November 11, 2009 at 7:01 pm
    Hi Dave,
    Thanks so much for the response!
    This isn’t really a situation of “Fix it in Post”… it’s more like one idea that morphed into another…
    The initial project was to have an aerial fly-over of the proposed pathway. (The camera view isn’t entirely fixed, but for the most part, it does follows the curvature of the path. The angle is looking forward and slightly down.)
    Initially, the client could view the footage next to GPS data in Google Earth and make observations about the impact the path would have on the geography. That worked as intended. Now, however, the desire is to have the pathway overlaid onto the video… so the client doesn’t have to keep going back and forth between the footage and the Mapping software.
    If this is even possible (esp for a rookie!) what kind of time-frame would I be considering… in relative terms?
  • Susan Dempster
    November 11, 2009 at 7:08 pm
    Hi Jim,
    Yes, there is constant motion in the video. It was shot from a helicopter moving forward over the proposed path at roughly 50 mph. The landscape is constantly changing due to the perspective (for example, the hills get bigger as you get closer, and so on.)
    Please forgive my ignorance – I’ve only dabbled in AE… If I can determine that my desired outcome is actually possible, I realize I’ll need to spend a lot of time learning how to use the software better…
  • Susan Dempster
    November 11, 2009 at 7:11 pm
    Thanks, Dave! I appreciate your honesty!
  • Eric Holzapfel
    August 10, 2010 at 6:01 pm
    Hello Jim,
    This is what I want to do. Draw a path, but over a non-moving image. You mention bezier points.
    Is this in FCP or AE or Motion or?? I am using FCP to create a travel film (stills and video), and want
    to trace over roads on a map.
    Thanks for great forum support,
    Eric
    Charybdis and Scylla Productions
    Final Cut Pro, Adobe After Effects, Photoshop
  • Jim Dodson
    August 10, 2010 at 10:23 pm
    I was suggesting you use bezier points in After Effects.
    Jim Dodson
