Activity › Forums › Adobe After Effects › Create a mask based off of a key
Posted by Billy Rodgeers on August 18, 2018 at 1:05 amIs there any way for me to easily create a mask based off the results of a green screen key. I was hoping for this so that I don’t have to make a mask and track it manually. Maybe is there some way to do it from an alpha channel?
Roei Tzoref replied 8 years, 1 month ago 5 Members · 6 Replies -
Billy Rodgeers
August 18, 2018 at 1:59 amIt’s entirely hypothetical, but if I would want to easily make a mask around something, it would be much easier just to do it based off a color selection right?
Andrew Somers
August 18, 2018 at 2:57 amAnimated masks are the realm of MOCHA. It’s not uncommon to use Mocha for masks even when doing green screen.
But, do you specifically need a mask for something and you can’t use the alpha channel?
Andrew Somers
VFX & Title Supervisor
https://www.GeneralTitles.com -
Steve Bentley
August 18, 2018 at 7:38 pmDon’t forget you can follow a track with and move, rotate, whatever another turned off version of your keying layer – in effect it becomes and independent “mask”.
Roei Tzoref
August 18, 2018 at 8:02 pmthere’s also layer-auto trace. you can create a mask based on alpha.
https://helpx.adobe.com/il_he/after-effects/using/creating-shapes-masks.html#create_a_mask_from_channel_values_with_auto_traceRoei Tzoref
2D/VFX Generalist & Instructor
♫ AeBlues Tutorials ♫
http://www.tzoref.com
