Activity Forums VEGAS Pro Create a DVD from a Bluray Project?
  • Create a DVD from a Bluray Project?
    Posted by Chris Evans on May 29, 2013 at 3:19 pm
    So I have now completed my first Vegas Pro/DVDA Bluray with some help on here and I am really pleased with the results. Next time it will be much easier!
    Now, I have some people that want the project on DVD.
    Is there an easy way I can convert the project to DVD spec? Can I just take the Vegas Pro project and get DVDA to burn it as a DVD? I am thinking it wont be that simple?
    Thayalan Paramasawam replied 13 years, 3 months ago 6 Members · 18 Replies
  • 18 Replies
  • Matt Geier
    May 29, 2013 at 10:33 pm
    Hi Chris,
    Standard DVD players read the .Vob format, what is the format you’re laying out with now? (AVI or MPEG etc?)
    I would recommend you download ConvertXtoDVD. Ive been using it for over a year now. It’s the easiest way to put videos into DVD format for me!
    It will convert your video files to the DVD format readable by all standard DVD players, then burn automatically to DVD!
    It is easy to use…give it a try.
    1. Download ConvertXtoDVD here:
    https://www.burner-software.com/AVI-to-DV…
    It can convert any video file.. like wmv, mpeg, asf, mp4, avi to DVD…
    Add or drag-n-drop as many video files as the DVD can handle…
    You’ll just need to insert a blank DVD..
    Then click “Convert”..
    Sit back and let yourself and your clients enjoy watching those video files on their home DVD player! =)
    ConvertXtoDVD has a lot of extra nice features as well…
    Maybe that will help.
    I’m happy to help further if I can.
    What do you use for Asset Management Software?
    What’s your hardware / network / shared storage setup consist of?
    Let us know!
    Matt Geier
    Matt Geier
    651-808-1338
    (Creative Product Evangelist)
    (Technical Sales Consultant)
    (Video Networking Solutions Consultant)
    (Creative Design Workflow Consultant)
    (Social Media Networks Consultant)
  • Thayalan Paramasawam
    May 30, 2013 at 12:35 am
    Hi……good morning
    Yes SVP can…….
    You can pulldown from 1920×1080 to 720×576 then use DVDA to burn Dvds
    Send your project details,i will guide you
    Thank you
  • Stephen Mann
    May 30, 2013 at 3:29 am
    Why are you telling the OP to downconvert? That is a guaranteed loss of quality, notwithstanding the marketing claims of “no data loss”. When you recompress already compressed video, you will lose some quality.
    The correct process is simply to encode the same project into the MPEG and AC3 files needed by DVDA.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
    May 30, 2013 at 4:03 am
    Thats right sir (Stephen Man).I am always pulldown from 1920×1080 to dvd resolution if customer reguest dvd.
  • Chris Evans
    May 30, 2013 at 2:28 pm
    OK, my BluRay project in SVP was rendered as MainConcept MPEG2 1920×1080-50i, 25 Mbps template and AC-3 Pro 5.1 audio.
    So, for best results, I take it I render the project again specifically for DVD? If so, what templates am I best using?
    Its a 1920×1080 project at 25fps with 5.1 audio.
    Thanks again all.
  • Dave Haynie
    May 30, 2013 at 4:26 pm
    You can take the DVD Architect project, change the project type to DVD, save it separately of course, and produce a DVD. Maybe.
    Sometimes graphical elements won’t line up perfectly, depending on the complexity of your Blu-ray. You may be doing things that don’t really map to DVD, despite the fact that DVDA is basically modeling Blu-ray as an High Def DVD (eg, it’s not doing many Blu-ray specifics).
    There’s an awfully good chance that’s all you need. Sure, the Blu-ray project video will have been compressed once from your originals to Blu-ray, and you’re recompressing to DVD in DVDA. But Blu-ray video contains about 6x as much useful information as DVD, so DVD video rendered this way will look pretty good.
    It will definitely get better if you re-render video from Vegas for the project… same thing you had before, but rendered to DVD’s MPEG-2 format. The real win here is less avoiding the extra compression step, and more that Vegas gives you much more control over MPEG rendering than you can get in DVDA. For example, for any longer project, you want VBR MPEG-2, which you can’t get in DVDA (last time I checked, anyway).
    Same goes with audio… if your DVDA project is using audio rendered at Blu-ray resolutions, it would have to be recompressed for DVD. If it’s the same old, same old 192kb/s or 448kb/s AC-3, it’s already in DVD format.
    -Dave
  • Stephen Mann
    May 30, 2013 at 9:36 pm
    Use the DVDA Widescreen template.
    Steve Mann
    http://www.mmdv.com
  • John Rofrano
    May 31, 2013 at 10:35 pm
    Change the DVD Architect project from Blu-ray to DVD Widescreen and Burn to DVD. That’s all you really ned to do.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
    June 1, 2013 at 12:48 am
    Good Morning Sir,(Mr.John Rofrano)
    So the mpeg file 1920×1080 can be authoring in DVDA for dvd 720×576?Right…….
    Thank you
  • John Rofrano
    June 1, 2013 at 1:28 am
    Yes, change you DVD Architect project to PAL DVD Widescreen.
    ~jr
