Create a DVD from a Bluray Project?
Thayalan Paramasawam replied 13 years, 3 months ago 6 Members · 18 Replies
Chris Evans
June 2, 2013 at 3:35 pmThanks once again all.
I didn’t think it would be as simple as just asking DVDA to make a DVD, but it works and looks fine.
John Rofrano
June 2, 2013 at 8:20 pmYea it’s that simple and for the most part it looks great. The are those who say that you should render a second time from Vegas specially for DVD to get the “ultimate” quality but I really can’t tell the difference and it’s so convenient that I just let DVD Architect take care of it.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
June 4, 2013 at 12:28 amGood Morning Sir,(Mr.John Rofrano)
There is black line on left and right side,when view from widescreen.I use 1920×1080 to pal dvd widescreen on DVDA.How to slove this probleum.
Thank You
Thayalan Paramasawam -
John Rofrano
June 5, 2013 at 12:02 pm[Thayalan Paramasawam] “There is black line on left and right side,when view from widescreen.I use 1920×1080 to pal dvd widescreen on DVDA.How to slove this probleum.”
Yea, that’s because PAL and NTSC Widescreen is not exactly 16:9 like HD is. If you want to fix this, you need to go back and re-render your project in Vegas Pro by either cropping the entire project to 16:9 or checking the options to [x] Stretch video to fill output frame (do not letterbox) when you render.
~jr
June 6, 2013 at 1:01 amGood Morning Sir,(Mr.John Rofrano)
Thank You very much for the reply,i will do some test and feedback to you.
Thank You
Thayalan Paramsawam -
June 8, 2013 at 1:46 amHi,Good Morning Sir,Mr.John Rofrano)
1)Is this option for Dvd pal widescreen 16:9?
2)When i rendering my footage for BLU-RAY out put,should i do Strecth Video,so i can make DVD output from 1920×1080 using DVDA.
3)At the moment for dvd output i pull down from 1920×1080 to 720×576 widescreen dvd pal.Is this right way.
Thank You
John Rofrano
June 8, 2013 at 3:29 pm[Thayalan Paramasawam] “1)Is this option for Dvd pal widescreen 16:9?”
This option is independent of any render type. It is not part of any template. You can use it to match the aspect of any format.
[Thayalan Paramasawam] “2)When i rendering my footage for BLU-RAY out put,should i do Strecth Video,so i can make DVD output from 1920×1080 using DVDA.”
You don’t need to use this for HD because HD is already 16:9. Leaving it enabled will not harm anything; it will be ignored.
[Thayalan Paramasawam] “3)At the moment for dvd output i pull down from 1920×1080 to 720×576 widescreen dvd pal.Is this right way.”
Yes this is the right way.
Just to explain the math behind the problem. 16:9 means 16 units wide by 9 units high where “units” could be any measurement you want. Here is the calculation for PAL Widescreen:
PAL Widescreen is 720 x 576 PAR 1.4568 (non-square pixels)
First you need to calculate the width in square pixels:
720 x 1.4568 = 1048.896 (1049)
That means PAL Widescreen is 1049 x 576 PAR 1.0
If we divide 576 by 9 and then multiply by 16 we will get the true 16:9 dimensions we need:
576 (pixels) / 9 (units) = 64 (pixels per unit) 16 (units) * 64 (pixels) = 1024 (pixels)
So 16:9 would be 1024 x 576 but PAL is 1049 x 576 which is why you need to either stretch or crop to make it fit 16:9.
Hope that helps.
~jr
June 8, 2013 at 4:28 pmHi Sir,(Mr.John Rofrano)
Thank you very much for the explanation,its short and very clear.Now i understand what is 16:9.So i need to learn more on editings and settings.Soon i have more questions………
Thank You
Thayalan Paramsawam
