Activity Forums Adobe Encore DVD Create a continuous-loop DVD for auditorum play
  • Create a continuous-loop DVD for auditorum play
    Posted by Butch Golden on August 4, 2016 at 12:44 am
    Hi all
    It’s been 5-6 years since I have done a DVD project of any kind and did ok enough with standard menu making but have never had a request for a continuous-loop/play disc. Don’t have a clue as to where to start.
    I have the video in my timeline and set as ‘first play’. Connecting the End Action to Chapter 1 does nothing and beyond that I haven’t a clue. The video stops at the end and that’s it.
    Any help would be very much appreciated.
    Thanks in advance
    Ricky Barrow replied 10 years, 1 month ago 3 Members · 2 Replies
  • Jeff Pulera
    August 5, 2016 at 2:04 pm
    Hi Butch,
    I believe the looping option is more a function of the DVD player than the disc itself.
    Considering that DVD is SD only, you might look into using a digital media player box – small box under $100 with USB input and HDMI output. Connect a small USB drive or thumb drive with H.264 content on it (HD resolution) and output HD video to high-def display, with looping turned on in player menu.
    I have a Western Digital WDTV that I bought several years ago, but there are a lot of imitators, Chinese stuff for instance, check Amazon. Some under $50 (read reviews!)
    I try to avoid SD video these days when I can
    Jeff Pulera
  • Ricky Barrow
    August 8, 2016 at 12:12 pm
    Set end action to go back to the start of your timeline.
    Ricky
