Activity › Forums › Maxon Cinema 4D › Create a brick wall based on texture?
Posted by Benjamin Brown on April 29, 2015 at 5:59 pmHi. Is there a way to create a brick wall that contains geometry that matches the bricks in an image/texture? Thanks
Brian Jones replied 11 years, 4 months ago 2 Members · 5 Replies -
Brian Jones
April 30, 2015 at 2:45 amDisplacement channel probably but making a good displacement map from an original coloured image is not trivial – though you can sometimes get good enough results (depending on what you need) just by desaturating the original image.
Benjamin Brown
April 30, 2015 at 2:06 pmThanks Brian-I need to collapse the wall too. Am I wrong in thinking that wouldn’t work?
Brian Jones
April 30, 2015 at 2:24 pmto get it to collapse you are going to need to build geometry. I don’t know if there is a cheat you could use, it would depend on the image, the shot angle, where you want the collapsed material to go (do you see it just fall or what?) etc.
Benjamin Brown
April 30, 2015 at 3:10 pmHeres the full scoop-its a couple of interviews shot in front of a brick wall. We want the brick wall to fall apart behind the subjects. Collapsing a brick wall is obviously not a big ordeal, but doing it such that the bricks match the bricks in the image…I haven’t figured out any way to do that. So as far as the angle goes, its pretty flat. Its just a wall behind a person being interviewed. The camera may possibly have to rotate away from the subject. Any other thoughts? Thanks for your time.
Brian Jones
May 1, 2015 at 1:48 amyou’d have to separate your people from the background, if you can do that then it is just a matter of using the wall image as a background and building the geometry to match. (easier said than done) Rectangular bricks? New? Old? (meaning a lot of shape irregularties). But without a separated subject when the 3D bricks move the 2D bricks will still be there.
