Activity › Forums › Adobe After Effects › Create 2d motion vector in After effects ?
  • Create 2d motion vector in After effects ?
    Posted by Dirk Moser on May 10, 2009 at 1:27 pm
    Is it possible to create motion vector inside after effects (let´s say from a square moving around) ?
    I want to use them with the turbulence.2d plugin from jawset.com !
    Pierre Jasmin replied 17 years, 1 month ago 3 Members · 3 Replies
  • David Bogie
    May 11, 2009 at 1:33 am
    Yes.
    Vector art can be animated in After Effects. But as soon as you apply a filter, it must be rasterized.
    I’ve never heard of jawset, is it an AE plug? Maybe you should ask the publisher of the system what the best way is to import data.
    bogiesan
  • Dirk Moser
    May 11, 2009 at 8:38 am
    Sorry if you got me wrong.
    I know that i can render out motion vectors for example by maya.
    I want to know if it is possible to create motion vectors form an object created in After Effects. (create a motion vector inside After effects with Re:map, Twixtor or another plugin)
  • Pierre Jasmin
    August 18, 2009 at 8:26 pm
    Sorry it’s a bit convoluted as it requires two products of ours right now, but if you read the part of going from “SmoothKit Directional” to “RE:Map Displace” to convert directions or normals into motion vectors, in the following tutorial: https://revisionfx.com/tutorials/AnimExpressTut/TUTORIAL_animatedImpressionism.html
    it would probably be useful to you.
    Something like Twixtor PRO generates actual motion vectors to next frame but it’s usually not that useful for the sort of effect you initially describe (unless like Video Gogh here it requires to render in order to maintain an history of what happened if you like).
    Pierre
