Activity Forums Adobe After Effects Crazy RAM Preview
  • Crazy RAM Preview
    Posted by Aaron Williams on October 6, 2010 at 6:32 pm
    When I hit the num0 for the RAM Preview it only gives me a second or two of render. Now believe me when I say it’s not because of memory. This is happening to comps I have easily rendered before, even comps with just a blank layer. I’m thinking it’s a setting that got switched. The way it usually works: Hit 0, it renders frames. Hit 0 again it plays those frames. Hit it again and it stops playing.
    What its doing now: Ok, kind of sporadic. Hit 0, it renders a few frames, then it will play maybe, hitting 0 will not stop it – but toggle between rendering and playing. You get more RAM preview with each hit but will only do a few frames at a time. Anyone know what button it is I hit?
    This is AE CS3. And I have tried restarting AE and the computer.
    Things are just not going well today.
    Aaron Williams replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
