Activity Forums Apple Motion Crazy Audio Sync
  • Crazy Audio Sync
    Posted by Wayne on August 22, 2005 at 4:29 pm
    Hello to All,
    I am doing what should be a very straight forward workflow between FCP and motion. I am on a G5 with all the latest updates of FCP studio 5.0
    I am selecting clips from the timeline and then doing a control click to send to motion with embed and launch options selected.
    one is a talking head with it’s associated audio on V1 and A1, A2. On V2 I have a series of JPEG photos which i have imported that will be superimposed over the talking head.
    The problem is that when it opens in motion and i play the talking head clip is correct in terms of the video track but the audio (from A1 and A2) is way out of sync – it is from a completely different of the clip. It is like I am seeing the proper video from the middle of the master clip and the audio is from the beginning of the master clip. Even if i go back to fcp and select only the talking head clip and it’s audio and do a send to motion i get the same problem. I have also tried selecting other simple video audio clips and I get the same problem. The video is linked to the audio in the clip and I tried both scenarios with the audio as a stereo pair and not – same crazy sync!
    Any ideas?
    Wayne Williams
    Portland Oregon
    Noah Kadner replied 21 years, 1 month ago 2 Members · 3 Replies
  • Noah Kadner
    August 22, 2005 at 4:52 pm
    Are there any audio filters applied? Sometimes roundtripping just doesn’t work properly. I’d suggest either not disabling about the audio or if it’s critical for your motion graphics design- export from FCP as a QuickTime animation codec movie and bring that into Motion.
    Noah
  • Wayne
    August 22, 2005 at 6:57 pm
    Hi Noah,
    Thanks for your quick response. I do not have any filters applied. this is as “vanilla” a clip as it gets, the one with the audio and the video.
    Your suggested workaround is interesting. As I understand it I would just select my V2 contents which are the photographs I want to animate to motion and export the V1 and A1, A2 contents (the talking head) as a quicktime file. I would then import the talking head Quicktime into motion so I can synchronize my animation with the audio?
    Would you just select the talking head clip, copy it into a new sequence, and then export as a quicktime movie? I did not quite understand “animation codec movie”. Assuming this is your guidance I’ll try it when I get home tonight.
    Thanks again,
    Wayne
  • Noah Kadner
    August 22, 2005 at 8:45 pm
    Yes that would do it. Animation is a QuickTime codec that introduces a low amount of recompression and preserves the alpha channel and is good to use when going back and forth between apps.
    Noah
