Activity Forums VEGAS Pro crashing while rending
  • crashing while rending
    Posted by Jerome Mcfadden on November 4, 2009 at 6:44 pm
    Using pro 9.0c 64 bit trying to burn an 20 gig iso file, then burn it to blue ray. Between 75 to 1oo percent the error message vegas gives me is program not responding. That after at least 8 hours of rendering. all drivers are up to date, defraged hard drives, have over 500 gig of room. running windows 7 64 on a I7 gateway at 2.67 chip speed. I have burn small iso files fine. oh yes have 6 gig of ram.
    Dale Spetz replied 16 years, 9 months ago 2 Members · 4 Replies
  • Dale Spetz
    November 4, 2009 at 9:12 pm
    Try setting the “threads” to the max: 16. On my i7 I have my Dynamic Ram at 1024.
    I have had much better luck using 4 drives: 1 for OS, 1 for “temp/scratch”, 1 for source, 1 for destination.
  • Jerome Mcfadden
    November 4, 2009 at 10:27 pm
    thanks for the responce but how do I do that. Setting the threads to 16. In windows or the bios?
  • Jerome Mcfadden
    November 5, 2009 at 12:36 am
    thanks again I figured it out its in prefences. Still I dont no why you raised the memory part up and cut your available ram down. How much ram do you have?
  • Dale Spetz
    November 6, 2009 at 3:18 pm
    I have 8 gigs of ram on an i7.
    The max 16 threads should make no difference on a system that perceives itself as an 8 core, but it seems to. In my case, it works, so I stick with it.
    Nor, do I understand the relationship between Dynamic Ram setting and rendering. But, I do seem to get different rendering behavior with different Dynamic Ram settings. In my case, rendering to Avid’s HD codec DNxHD-145, I find that the settings of 16/1024 work. Other settings, I have had less luck with. It may be codec dependent, but it may be worth a try for you.
    And, as mentioned before, I have found it very helpful (higher render success rate) by using 4 drives.
