Activity › Forums › Apple Final Cut Pro Legacy › Crashing whenever Log and Capture is attempted
  • Crashing whenever Log and Capture is attempted
    Posted by Conan Skyrme on January 14, 2008 at 7:04 pm
    As stated in the subject line, I am trying to Log and Capture footage from a D-Beta deck but Final Cut crashes the moment I select ‘Log and Capture’ from the file menu (the capture window appears briefly before the crash happens). I have restarted the computer (mac G5 tower) several times and this has not helped.
    Any advice? Many thanks.
    Philip Johns replied 18 years, 8 months ago 4 Members · 3 Replies
  • Jeremy Garchow
    January 14, 2008 at 7:47 pm
    Trash your prefs.
    What version of everything are you on and what capture card/drivers, give us everything.
  • Berenger Capmany
    January 14, 2008 at 7:58 pm
    If trashing prefs is not working…
    re-install Quicktime…
    to do a complete Quicktime reinstall… you should trash the Quicktime receipts on /Library/receipts first.
    This will cheat Quicktime installer and will do a complete reinstall (not a zero K update)
    have worked for me several times.
  • Philip Johns
    February 6, 2008 at 6:49 am
    Hey, I had this problem too. I had just re-installed the OS and couldn’t get the firewire to recognize, plus it also crashed if I went to capture. I found that getting rid of the preference files didn’t fix this problem but re-installing Quicktime did fix it. Cheers 🙂
    Philip Johns
