Activity Forums Avid Media Composer Crashing when tring to install Media composer 6.5
  • Crashing when tring to install Media composer 6.5
    Posted by Vasja Mihelcic on June 24, 2013 at 10:30 am
    Hello,
    I have problems installing Avid Media composer 6.5. It crashes upon the process of installation.
    I,m running iMac i7 3,4 Ghz intel Core, 32 GB 1600MHz, Fusion drive (Late 2012) OS x 10.8.3
    Any idea?
    thx
    VM
    Kendall Kaiser replied 12 years, 8 months ago 3 Members · 3 Replies
  • John Pale
    June 24, 2013 at 2:56 pm
    Copy the installer from the disk image you downloaded to your desktop. Unmount the disk image.
    I had the same problem. Worked fine after copying to the desktop.
    It’s a bug. Avid is aware of it, but doesn’t know what causes it yet. Doesn’t happen to everyone.
  • Vasja Mihelcic
    June 28, 2013 at 7:00 pm
    I did it again manually and it worked…bizare, but thx anyway.
  • Kendall Kaiser
    December 30, 2013 at 4:19 pm
    I’ve run into this several times with 6.5.4 on osx.8.5 and 8.4. I’m trying the copy to desktop to fix it.
    Thanks for the info!
