Activity › Forums › Adobe Premiere Pro › Crashes with multiple processors
Posted by Brian Scott on September 12, 2008 at 11:21 pmI have a new rig with 2 quad-core processors. I haven’t had any luck getting Premiere to run. It crashes very soon after I start. Are the multiple processors the problem? I’m running under XP 64, which the Adobe sight says is OK, but is that the problem?
Brian Scott
President
Image Design Productions, Inc.Brian Scott replied 18 years ago 4 Members · 14 Replies -
Harm Millaard
September 13, 2008 at 6:28 amThe Adobe site explicitly states 32 bit ONLY, so your sight was wrong.
Harm Millaard
Brian Scott
September 13, 2008 at 12:23 pmHere is what I read on the Adobe site:
“While Adobe Creative Suite 3 software is natively 32 bit, these applications will run on 64-bit versions of Windows”However – the software will not run on the 32 bit version of windows on this system either. After Effects and Photoshop run fine. Here are the main system components:
Dual AMD Opteron Model 2354 (2.2 GHz) (Dual Quad−Core)
2 x 4GB DDR2−667 (8GB total)
NVIDIA Quadro FX 4600 768MBMy question remains – could the 8 cores be an issue?
Brian Scott
President
Image Design Productions, Inc. -
Peter Corbett
September 13, 2008 at 1:29 pmI’m running Vista 64 & CS3 Suite on an 8-core Intel Skulltrail without these problems. It may be a different story for the 64-bit version of XP though.
Peter Corbett
Powerhouse Productions
http://www.php.com.au -
Harm Millaard
September 13, 2008 at 1:30 pmAdobe states: Microsoft® Windows® XP Professional or Home Edition with Service Pack 2 or Windows Vista™ Home Premium, Business, Ultimate, or Enterprise (certified for 32-bit editions only)
Intel Quad cores have no problem with 32 bit OS.
Harm Millaard
Peter Corbett
September 13, 2008 at 8:58 pmHave you considered putting in Vista 64 Brian? I think the new CS4 will be more compatibility. It’s being launched in a couple of weeks and probably on sale soon after. You’d have to be sure your hardware has V64 drivers though.
Peter Corbett
Brian Scott
September 13, 2008 at 10:31 pmI’m hoping to avoid Vista all together. Several of my other apps don’t support it. I’m hoping I can jump over Vista to whatever comes next.
Brian Scott
President
Peter Corbett
September 13, 2008 at 11:50 pm[Brian Scott] “I’m hoping to avoid Vista all together. Several of my other apps don’t support it. I’m hoping I can jump over Vista to whatever comes next.
Brian Scott
President
Image Design Productions, Inc.”If your apps don’t support then you’ll have to wait I guess. But for me I haven’t found a single video/graphics/compositing/encoding application that won’t run/install on Vista 64. The ability to use more than 4-gig of RAM has fixed our memory crashing problems and the system runs with much more stability than our old XP 32-bit platform. I’d investigate Vista 64 compatibility thoroughly with your other apps before you dismiss it.
Peter Corbett
Lee Cheow hee
September 14, 2008 at 6:48 amI have a similar problem when I moved up to Quad Core processors.But it is with Studio Max. The rendering simply freezes every few frames. could it be a compatibility issue?
https://forums.creativecow.net/readpost/18/856241Lee Cheow Hee
Stan Creative -
Lee Cheow hee
September 14, 2008 at 6:50 amI have a similar problem when I moved up to Quad Core processors.But it is with Studio Max. The rendering simply freezes every few frames. could it be a compatibility issue?
Stan Creative -
Brian Scott
September 14, 2008 at 10:52 amI haven’t had a problem with Max – or any others actually. If I limit the machine to 4 cores at boot-up, Premiere will run. This doesn’t seem like a great solution since I lose half the horse power I paid for.
Brian Scott
President
