Activity › Forums › Adobe Premiere Pro › Crashes while saving
  • Crashes while saving
    Posted by Scott Dudgeon on November 9, 2009 at 8:30 pm
    Adobe Premiere CS4 keeps crashing while trying to save. The project is a big one. About 5,000 video clips. I am using the same project to create a new 30 min sequences every week. It will crash about 3 or 4 time a day while trying to save. Quitting Adobe Premiere and restarting it has seemed to help.
    I am on an IMac with 4 GB RAM. The clips are stored using and external drive with a 1000 Gigabit switch connected by an ethernet cable.
    Do I need more memory?
    Mattia Buzzarello replied 12 years, 6 months ago 3 Members · 5 Replies
  • Mike Velte
    November 10, 2009 at 11:48 am
    Memory is likely an issue, but using the same project file over and over sounds like a recipe for suicide. After completing week 1 you should have “saved as ” week 2, then for week 3, reopen week 1 and “save as” week 3. This process will avoid having an incredibly large project file.
  • Scott Dudgeon
    November 10, 2009 at 5:56 pm
    I am doing a “save as” for each week, but I don’t go back to the first week cause I am always adding video clips & sequences. I also don’t want to delete any of the sequences cause I am often going back to previous weeks and pulling out parts for repeated segments for the current week.
    My most recent project file is about 190MB. It has about 20 30 min sequences and about 5,000 clips in assorted bins (most are about 5sec each). I am sure I can clean up some of the bins but the library video is extremely important.
    Any ideas?
  • Mike Velte
    November 11, 2009 at 11:51 am
    190 MB project file is extremely large! You have too many eggs in that basket. Without looking at your project it is difficult to make suggestions, but you cannot continue on that path without hitting a brick wall if you have not already…
  • Scott Dudgeon
    November 13, 2009 at 3:12 pm
    Thanks for there help. It seems like it could be a mixture of things, but does anyone know why it is only crashing when I attempt to save and at no other time? Is this a memory issue, external drive, or something else?
  • Mattia Buzzarello
    April 3, 2014 at 10:25 am
    I solved this really annoying problem by creating a brand new project in which I imported the sequence I was working to.
    Unfortunately I had to link the media that went offline and render the whole sequence. Besides this minor issue, now I can save my project just fine
