Activity Forums Apple Final Cut Pro Legacy Crashes in Final Cut 7.03 with Snowleopard
  • Crashes in Final Cut 7.03 with Snowleopard
    Posted by Marc Puttkamer on January 18, 2012 at 4:11 am
    Having too frequent crashes- running our FCP system and Apple Pro Res files. We have recently upgraded our system- Final Cut 7.03, latest Snowleopard 10.6.8.; and we have current drivers/firmware for our Kona Card 3. We are running a 14tb RAID drive on the system- through SAS/SATA cables. 2 things have been happening lately- when we have a few timelines/sequences up at once- seems to cause first a flickering image- then and “out of memory” warning and crash;
    also- what happens we’ll get a big timeline/sequence up- or one with EX-1 footage on it- and it will crash straight out with no warning giving us an AJA Video output codec- – error warning.
    Any ideas about what’s happening here? Could this be Kona Card related? Thanks.
    Tom Asakawa replied 14 years, 8 months ago 3 Members · 3 Replies
  • Michael Gissing
    January 18, 2012 at 7:38 am
    Did you upgrade by installing over FCP6? Best advice here is to do a clean OS and FCS3 install on a new drive.
    Also there have been issues for some people with graphics card and hard drive drivers going from 10.6.7 to 10.6.8 . The .8 upgrade was purely for FCPX and the apps store so if you can avoid this OS upgrade FCS3 will run better.
  • Marc Puttkamer
    January 18, 2012 at 11:30 pm
    Thanks for that advice. We’re in the middle of a big job right now, so a little nervous about changing operating systems. We’ve tried changing the AJA Kona card driver, and shutting off the Kona Card- external output- this seems to have helped for now….it’s more stable.
  • Tom Asakawa
    January 22, 2012 at 11:41 am
    I’m having the same FCP/Kona3 problem as Marc (OP) & other posts here;
    Experiencing diminished performance & crashing out of FCP 7.0.3
    crash log states ; “AJA videoOutput Plugin” at issue, although crashing without that particular line, too.
    other issues; flash frames, black ‘frames’, failed renders, “out of memory” messages.
    (multicam) sequence trt: 75 minutes
    Sony XDCAM HD
    FCP project file = 255mb
    ANY help would be Much obliged…
    tia,
    -tom
    Mac Pro 2.93 8-core 16GB OS 10.6.8
    Kona 3
    NEC3090WQXi
    Quadro 4000
    Caldigit HDPro2 8TB
    Prism ADA8XR
    Gen10
    FCP 7.0.3
    Smoke 2012 (10.6.7)
    Media Composer
    Kona 3 driver v10.0.1
    Quadro driver v256.02.25f01
