Activity Forums Apple Final Cut Pro Legacy CRASH WHILE CAPTURING…pls HELP ME
  • CRASH WHILE CAPTURING…pls HELP ME
    Posted by Alvaro Lanciai on January 11, 2010 at 11:29 am
    hi there,
    I’ve a serious problem….
    I’m trying to capture 2 tapes of footage shot in HDV 1080i50.
    I use HDV-APPLE PRORES 422 (HQ) codec and SONY HVR-M15AE deck.
    1st tape:
    contains short clips (max 1 or 2 minutes) and no problems occured during capture
    2nd tape:
    contains a long clip (45 minutes) and everytime i try to capture it, FCP unexpectely quits after 26:10:00 of capturing….
    it seems to be a problem due to clip’s duration and codec because it happens also on other machines with the same clip’s duration (also with different footages) and with the same codec…if I use HDV prores 422(not HQ) it works normally…
    I already checked my system settings about LIMIT CAPTURE FILE SEGMENT SIZE (not activated), already trashed preferences….
    ANY SUGGESTIONS…?
    Thankyou
    MAC INTEL dual quadcore 3ghz
    8gb ram
    macos 10.5.8 and macos 10.6
    fcp 7
    Walter Biscardi replied 16 years, 8 months ago 3 Members · 2 Replies
  • Adam Taylor
    January 11, 2010 at 11:48 am
    there is no real benefit from using the Prores 422 HQ with HDV material…all you are doing is creating a much larger file, which may be part of the reason you are having problems. Stick to non Pro Res and you should be fine.
    Gary Adcock explains his findings in this enlightening article….
    https://provideocoalition.com/index.php/apple/story/prores_a_closer_look/
    adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
  • Walter Biscardi
    January 11, 2010 at 12:11 pm
    No reason for ProRes HQ with HDV footage. ProRes is what is recommended for all frame sizes 1080 or less.
    If you’re cutting off at the exact same time each time, sounds like a formatting issue on the hard drive array. Make sure your drive is property formatted and clean.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
