Activity Forums Apple Final Cut Pro Legacy Crash rendering HD sequence
  • Crash rendering HD sequence
    Posted by Dave Beaty on April 29, 2008 at 1:38 pm
    Final Cut Pro 6.0.3 OS 10.5.2 Intel – clean install of FCPro. not using 3rd party filters.
    I replied to another post from the 15th after I saw someone else was having this problem…
    I am having serious problems rendering certain HD material. Each render of a 40 minute DVCPro HD 1080i sequence produces numerous crashes on various clips. These crashes are preceded by numerous error in console. Most of the clips have motion and distort and broadcast safe filters applied.
    Its a particularly nasty bug in that an hour or more of rendering will be lost if you don’t render in small pieces – 4 or 5 clips , saving after each render.
    My sequence is using high precision YUV rendering option. Smoothcam clips are especially prone to the render crash.
    I discovered that if I open console I can predict the crash a few seconds before it happens. If the FCPro errors start appearing, then I quickly cancel the render.
    I have reported this using Apples Auto Report system and FCPro’s feedback…
    Here is a sample the error codes that start cascading down the console:
    4/29/08 9:22:30 AM [0x0-0x1c01c].com.apple.FinalCutPro[204] *** error: can’t allocate region
    4/29/08 9:22:30 AM [0x0-0x1c01c].com.apple.FinalCutPro[204] *** set a breakpoint in malloc_error_break to debug
    4/29/08 9:22:30 AM [0x0-0x1c01c].com.apple.FinalCutPro[204] Final Cut Pro(204,0xa00adfa0) malloc: *** mmap(size=22163456) failed (error code=12)
    4/29/08 9:23:44 AM [0x0-0x1c01c].com.apple.FinalCutPro[204] Final Cut Pro(204,0xa00adfa0) malloc: *** mmap(size=22163456) failed (error code=12)
    4/29/08 9:23:44 AM [0x0-0x1c01c].com.apple.FinalCutPro[204] *** error: can’t allocate region
    4/29/08 9:23:44 AM [0x0-0x1c01c].com.apple.FinalCutPro[204] *** set a breakpoint in malloc_error_break to debug
    4/29/08 9:23:45 AM [0x0-0x1c01c].com.apple.FinalCutPro[204] Final Cut Pro(204,0xa00adfa0) malloc: *** mmap(size=22163456) failed (error code=12)
    4/29/08 9:23:45 AM [0x0-0x1c01c].com.apple.FinalCutPro[204] *** error: can’t allocate region
    4/29/08 9:23:45 AM [0x0-0x1c01c].com.apple.FinalCutPro[204] *** set a breakpoint in malloc_error_break to debug
    Dave Beaty
    Dreamtime Entertainment
    1625 SE 46th St
    Cape Coral FL 33904
    239-549-4081
    800-446-7575
    dave@dreamtimeentertainment.com
    http://www.dreamtimeentertainment.com
    Jon England replied 16 years, 7 months ago 2 Members · 1 Reply
  • Jon England
    February 4, 2010 at 9:31 am
    Looks like i’m having this error with exporting a project to XML…
